Hello from Kent
Re: Hello from Kent
Postby Wheeledbeast » Sat Sep 06, 2014 9:45 am
No drama, I had the same problem. Before you start uploading you can reduce the size in Ms Paint.
Right click on the photo in your folder and choose “open with” you will get a list of programs, you need to choose the one called paint, the icon is like an artist’s pallet. (When the picture opens you will probably only be able to see one corner of it).
On the menu bar in paint there is a box labelled select. If you click on select there is an option called select all, you choose that. Then just next to select is an option called re-size. Click on re-size and change the percentage from 100 to something like 20. (This has ruined your photo, but don’t worry you will not save it :!: ). On the other side of the select button is the cut (scissors) Icon. Press this and your photo will disappear. Then click the file menu (Top left) and press the “new” button.
You will be asked if you want to save the picture, say NO :!: . A new small blank picture should appear. ( a big blank picture appears, grab the bottom right hand corner of it and drag it to small). Next click the paste clip board icon (just next to select). Your picture should reappear, but much smaller than it was. You will need to save this photo under a different name, and then you can upload it.
I know this seems complicated, but it gets easy with a bit of practice :? . There is probably a faster way to do all this, may be some one more “computer-ish” than me will be able to help us with, but this way will definitely do the job for now. Good luck, looking forward to seeing the photos :) .
Titch
Re: Hello from Kent
Postby Titch » Sun Sep 14, 2014 6:06 pm
Hopefully there will be a picture taken at Folkstone show 2 days after its MOT
Titch
Re: Hello from Kent
Postby Titch » Sun Sep 14, 2014 6:08 pm
:DD wheeledbeast :DD
Re: Hello from Kent
Postby 22900013A » Sun Sep 14, 2014 7:02 pm
That is very nice!
Re: Hello from Kent
Postby DasLandRoverMan » Sun Sep 14, 2014 7:53 pm
Is this the six cylinder one, or the 3.8 BMC truck?
Excellent job either way.
Titch
Re: Hello from Kent
Postby Titch » Sun Sep 14, 2014 8:33 pm
This is the 6 pot that is ours to keep , Pat's daughter still has the other one with the BMC 3.8, she's doing a few jobs on it at present, once it is ready, LRC mag are going to do an article on them !
Titch
Re: Hello from Kent
Postby Titch » Thu Oct 02, 2014 3:33 pm
Titch wrote:This is the 6 pot that is ours to keep , Pat's daughter still has the other one with the BMC 3.8, she's doing a few jobs on it at present, once it is ready, LRC mag are going to do an article on them !
Update, the other one "Tiny" is going on the 13th October to Gumtree who are going to transplant a sixpot back into her, so it will be up and running again shortly ( it had an overheating issue ) and they both will be featuring in a national mag ;) together with their story :DD :DD .
Re: Hello from Kent
Postby 22900013A » Thu Oct 02, 2014 3:36 pm
Is that the one I suspect is an ex-SEB vehicle?
Titch
Re: Hello from Kent
Postby Titch » Thu Oct 02, 2014 4:26 pm
22900013A wrote:Is that the one I suspect is an ex-SEB vehicle?
yes Dan, that is the one we spoke about at Peterborough
Re: Hello from Kent
Postby 22900013A » Thu Oct 02, 2014 4:54 pm
I look forward to seeing more about it. :)
