MKII Hydraulic winches
Re: MKII Hydraulic winches
Yes and they appear to have their own number sequence
What is the number on the new one you got recently?
Hi, i have a MK1 winch & I see the numbers under the pump but can't see any numbers on the winch at all.... where should I be looking ?maudie wrote:I had a rivet counting moment the other day.
Serial Numbers currently in the collection:
Mk1's (AEH.HYD.***)
2, 72, 315, 564, 890, 1030, 1040, 1049, 148 FC, 275 FC
Earliest date: 1959
Latest date: Appears to be 1968 but not entirely convinced at the moment due to discrepancy in the pump number (could have been replaced) as 1030 & 1040 are dated 1965
Mk2's (introduced circa 1967 / 1968)
604, 812, 1005, 1007, 1064, 1092, 1169, 1362, ?, ?, ?, ?, ?, ?, PFL/103
It appears sometime between 1971 & 1974 they stopped stamping serial numbers on them. PFL/103 is the youngest in the collection dated 1980. Earliest date appears to be 604 (1968)
I'd like to know if anyone has a sub 600 number on their mk2. I have a theory the mk2's didn't start at 0. Also if anyone has a mk1 with any markings that would give it away as preproduction or higher than 1049. Although I'm not sure what the markings would be like for a pre pro winch?
Regards
Rob
Hi, the mk 1 winches usually have the serial number stamped around or on the 'Land Rover' badge. Sometimes, if they have been exposed to the elements they can be quite hard to see. Regards Rob
1962.
If my theory and research is correct the serial number of yours should be between 315 & 890, as long as its the original pump. The only exception would be if its a Forward Control winch, which appear to have a separate numbering system.
And correct you are, I had given up then just now while doing a different job the sun caught it & I could see a number, it's out of the way on the inside face so I scraped the paint & it's 506.maudie wrote:1962.
Users browsing this forum: No registered users and 13 guests
