FAB's cab has a different button, but in the same place ( if you see what i mean)
viewtopic.php?f=20&t=121&start=10
They are all outies though. Why have you taken the needle off the speedo
Mmmm digestives
ps Who is Kev and why does he need to be kept upright?
Mmmm digestives
in case of this http://www.liveleak.com/view?i=2e3_1369935294
Kev is actually Key, and I assume the label is something tondo with the fact the key can be turned back one position to the left of the 'off' position. No idea what it does.
The needle hasn't been on the speedo for years. It was around 1996 when it last saw the road, so has lost it at some point in the intervening period.
Come to think of it keeping Kev upright and reasons for doing so is a lot more amusing.
In my experience unidentified switches in Land rovers only do two things. They either do noting at all or set something on fireDasLandRoverMan wrote:Kev is actually Key, and I assume the label is something tondo with the fact the key can be turned back one position to the left of the 'off' position. No idea what it does.
I can only agreeIn my experience unidentified switches in Land rovers only do two things. They either do noting at all or set something on fire
If it isn't broken fix it till it is.
Derby and Nottingham shire local chimney sweep, chimney builder and Land Rover idiot
I’m not sure you can say this in the internet any more either, but I’ll do it any way… Do you know what it is yet?
Resisting temptation to drag it down ever further...
It's the top vent off of a smiths heater and some other bits.
Other bits of a vacuum cleaner to be exact
I have ( I fear ) a cunning plan
Firstly I have butchered the Smiths heater a bit and then I have created this beauty /monstrosity.
Users browsing this forum: No registered users and 133 guests
