Hello from Florida
wrellis
Hello from Florida
Postby wrellis » Mon Feb 26, 2018 7:32 pm
Greetings from Florida, USA.
Technically I don't have a one-ton. What I have is a 2a 109 Dormobile that I want to put a one-ton chassis under. The fabricator is warning that the steering relay is a very different bolt on affair. Every reference I have found so far suggests that they are the same.
Would someone be so kind as to expand on this.
Thank you,
Will
Re: Hello from Florida
Postby DasLandRoverMan » Mon Feb 26, 2018 9:12 pm
He's most likely confusing 'One Ton' with 'Stage 1' which does have a different steering relay setup.
The One Ton uses the same relay and mounting -Although the steering box is a different ratio- as the contemporary Series IIA/III.
Postby 22900013A » Tue Feb 27, 2018 8:09 pm
They may also be on about the steering damper bracket, which comes in two flavours - bolt on or welded on. They were bolt on on 1-Tons and then welded on on later vehicles.
