Hi all,
At the Peterborough show this weekend I got talking to a 2B FC owner and he advised I remove my engine/propshaft driven fan and go electric - apparently the system can wear the water pump bearings very quickly and the pump is no longer available?
Seems a shame to lose the originality to me.
Can anyone comment on:
Pump wear with prop driven fan
Pump availability
Cheers
Theodor Marte 1972 6 cylinder SIII converted to a 2B at new
Prop driven cooling fan question
Corroded66
- Newbie
- NZ2AFC
- Running on six!
Re: Prop driven cooling fan question
Hello Theodor,
I would keep the shaft. Make sure the shaft is balanced. Keep a regular check on the pump, and if the pump wears, the bearing is the same as all S2-S3 4&6 cly engines (RP#523354)
Corroded66
- Newbie
Cheers, appreciated
