ENV Rear Axle
JohnOShea
ENV Rear Axle
Postby JohnOShea » Thu Feb 11, 2021 12:44 pm
Hi all,
Before I ask the wider Land Rover collective I thought I’d ask you all who know more about 1-ton components.
How much driveshaft play is acceptable for a Rear ENV diff? I can turn it by hand a few degrees each way before the wheels turn. (When I get a chance I’ll measure the exact amount of degrees) Everyone has always told me they’re indestructible and I’m fairly certain this one hasn’t been abused so I just wanted to check if it’s normal.
Cheers,
Johnny
NZ2AFC
Re: ENV Rear Axle
Postby NZ2AFC » Thu Feb 18, 2021 10:46 am
Hello Johnny,
'a few degrees' is about normal as there will be some movement in the splines at the drive flanges.
Users browsing this forum: No registered users and 22 guests
