Best do an Intro then!
warthog72
Postby warthog72 » Thu May 03, 2018 11:13 pm
Morning All,
Thought I’d join up and see if there is still some interest out there! I’ve just managed to get hold of my 3rd 2B forward control. SNV110G which has a lovely white (household emulsion) type paint job, but is an almost entirely original home market 2.25 Diesel 2B.
It runs and sort of drives, but needs the clutch slave cylinder replacing to make it truly a driver!
I would ask if anyone knows the whereabouts of my previous 2B which was a Perkins engined beast which I owned some 24-25 years ago, it came to me with no back end of the cab and top so the only thing available was 2 x 109” back bodies, which I joined together to make a single “pick-up body” on the back, with ally flaps to cover the wheel arch holes where they didn’t need to be.
It got painted JCB yellow as I wasn’t that well off at the time and it’s all I had (and the front end was Yellow already, I assume as it may have been a cherry picker at some point) and I sold it to someone connected to the then FC register based in London near Manor Royal industrial estate/bottom of the M1 in London.
I’ll try and dig out a photo of the number plate and would appreciate if anyone knows where she might be I would appreciate it!!
I’m also looking for the front end of a 2B ideally (but a 2A would work) as I have a hulk with no numbers that seems to have seen better days, the back end is OK, but the front not, so wanted to find a way to cost effectively put her back on the road... I have most of the undercarriage, but was looking for the bits from the front axle forward (not including the front axle) so body work and steering and body support framework etc.
If anyone has any of this please let me know as would love to get another one back on the road once I’ve done the Clutch on SNV110G.... I’ll get bored otherwise!
Many thanks
:2b:
If it ain’t broke, don’t fix it (unless it’s a Landy, then it always needs a tinker...)
:2b: SNV110G
1953 Series 1 that I dragged back from Tanzania
1995 last of the Soft dash RRC (proper Range Rover!)
And a few others.... :shock:
Re: Best do an Intro then!
Postby 22900013A » Fri May 04, 2018 7:17 pm
Hello and welcome.
I can't help with the motor you are after, but I know SNV110G was an ex East Midland Electricity Board vehicle, and would have looked like this when new (the rag top one)
warthog72
Postby warthog72 » Sun May 06, 2018 11:37 pm
Thanks!
It looks nothing like that now.... it’s been painted with a household emulsion by the looks of it on some and has been red at some point in it’s life... but I have seen that blue colour lurking underneath, although hard to tell which paint job on what timeline, but that helps!
Much appreciated
:2b: SNV110G
Postby 22900013A » Mon May 07, 2018 7:40 am
I remember seeing it before and the combination of the Northampton reg plate and electric blue paint helped identify it. Fixed sides as well which I recall EMEB seemed to favour. And diesel engines!
Users browsing this forum: No registered users and 26 guests
