Hello from the Borders
Scoguy84
Postby Scoguy84 » Mon Apr 16, 2018 8:40 pm
I should have introduced myself earlier. I have always been interested in series Land Rovers my first being a 1955 107 pickup and my 2nd that is my current Series IIB GPO Forward Control.
Still getting used to the layout working of this forum :) new to me.
I moved it for the first time since 1991 under its own power. Short runs up and down the road. Surprisingly peppy even if its just in 1st gear :)
Fan assembly needed complete. If you can help I would be very keen to purchase. Shaft, bering support, flange and fan.
I also would down the line like to correct the cab conversion back to original. Again if you have a cab rear and roof section compleat glass seals etc.
Roof cab parts needed
Fan assembly
Scoguy84
Re: Hello from the Borders
Postby Scoguy84 » Mon Apr 16, 2018 9:36 pm
Not sure if this will work. The first attempt turning over and a little cough. Prior to this I oiled the bores and turned on the handle very so often for a few weeks. Zero smoke on start up I was amazed :) Dropped the oil will set tappets and freshen up the points leads etc.
[youtube]https://www.youtube.com/watch?v=1awQ8OV6wFI[/youtube]
2nd attempt first run
[youtube]https://www.youtube.com/watch?v=IA2ju612Eh8[/youtube]
Postby DasLandRoverMan » Tue Apr 17, 2018 7:48 pm
Looks like we've found the third of these FC's.
There were 3 built for the GPO, one was converted to Dropside truck, the other was sold to another member of this forum up in Aberdeen.
Unless you bought it from him?
There's a few of us in the North of England, and the Scottish Borders.
linesrg
Postby linesrg » Fri Apr 27, 2018 10:39 am
Das,
No I've still got the one in Aberdeenshire. I have no idea when anything will get done with it..................
It's undercover so it isn't deteriorating in any great way.
I have contacted ScoGuy84 directly already.
I guess one day we need to get all three in one location??
Regards
Richard
1952 86" Prototype Welder, 1953 ALRC trialler (still building), a FC 2B, Stage One V8, a 110 Puma Defender and a 1990 20V Audi quattro.
