Tie rod rubber underneath the gearbox
The "So you think you know Land-Rovers..." topic has got me thinking - the rubbers on the tie rods beneath the gearbox are shot, would need replacements but can't find any available. Does anyone know a source? I could not find part no. in the catalogue as the rubbers are either not there or are hiding in a section in which I wouldn't go looking for them...
helicalrider
Re: Tie rod rubber underneath the gearbox
http://www.lrseries.com/shop/product/li ... UFFER.html
Perhaps this parts work too. But i`ve no info about the measures.
http://images.google.de/imgres?imgurl=h ... 9&biw=1239
Cheers Marc
Cheers Marc
Cheers, will take a look at mine as those on my truck look different-shaped, but it may be due to their deterioration.
I got mine from Tony Arnold at Land Rover Fasterners
They're the same as the smaller size lower bushes for 109 rear shock absorbers aren't they? The ones shaped thus;
__
)__(
If you get the idea from that? They're also useful for the top of the ARB links on the front of a IIB also.
__
)__(
Just read the links, seems not.
They do work for the Anti Roll Bar though.
http://www.johncraddockltd.co.uk/other/ ... e-rod.html
They are not too expensive...
Cheers, much appreciated, apparently the main problem was my ignorance of how it's called - the actual availability of the part doesn't look that problematic
Users browsing this forum: No registered users and 75 guests
