So you think you know land rovers.......
Re: So you think you know land rovers.......
The two outer bits look like they might be part of the cab structure.
Can we have a picture from another angle?
Warm - but any more photos would give it away
I'm guessing they are a bit that regularly gets lost or is missing,may be something to do with the under seat tool tray
Cold on location but probably something that is often missing.
Mounting brackets for the front splash guards between the outrigger on the chassis and on the bottom of the seat box?
freezing.....
helicalrider
The parts look like trim panels of the truck cab corner windows.
Correct!
Photo shows partly installed in MPX
... all though i must confess that i dont have rear quarter lights in my truck cab. I had the holes for them but i just warmed up side pannal off the bath and stuck it in the holes.
not quite factory spec
Users browsing this forum: No registered users and 18 guests
