Postby Wheeledbeast » Thu Jul 28, 2016 8:34 pm
Shots of me paddling at the sea side this morning :D
Postby Wheeledbeast » Thu Aug 04, 2016 3:44 pm
Having some ruff running lack of power problems at the mo. I fitted a new set of points after the AA had to fix me, but i still seem to be down on grunt. :(
Postby Wheeledbeast » Sun Aug 07, 2016 3:29 pm
I think i had the wrong points set, changed the codenser as well now and all seems fine. I do have a problem of lots of smoke out of the oil breathers, i'm thinking that might be piston rings :? any body got any thoughts :?:
Postby jim » Wed Aug 10, 2016 7:14 pm
:D Nice pictures
"If you can dream it, you can achieve it."—Zig Ziglar
''Logic will get you from A to B. Imagination will take you everywhere.'' — Albert Einstein
Postby Wheeledbeast » Sun Aug 14, 2016 3:40 pm
Building up to a camping expedition to Wales. Some one had better ring the AA and warn them :D
Postby Wheeledbeast » Fri Aug 19, 2016 8:58 pm
Photos of the camping trip to Wales attached. Made it there and back with no serious issues. I am burning quite a lot of oil on over run so down the steep hills was interesting for the guys behind me. I did quite well on the climb up the A470 pass at Dinas Mawddwy. Going west it was second gear about 20mph, although the engine temp went up to 90, hotter than i have ever seen it get :!: (normaly 70-75).Going east was easy mostly thrid geat at about 25mph and a normal engine temperature :) also i sem to be getting close to 12mpg on the gas, i think that is pretty good :)
THe new jib did a good job as a bike rack, but it misses all the bungee points the old jib had. I will have to give that some thought.
Postby Wheeledbeast » Sun Aug 21, 2016 6:15 pm
... And a few more camping shots
Tomorrow is the start of the big engine stripdown :?
Postby DasLandRoverMan » Sun Aug 21, 2016 6:57 pm
Tdi conversion?
Postby Wheeledbeast » Mon Aug 22, 2016 7:02 am
I need to have a look and see where all this oil smoke is coming from. I am a bit nervious about taking it all apart in case i find something terminal :( I think a TDI would be too noisy) i did wonder if i shoud try and shoe horn a V8 in, but ultimatly i am hoping i can fix the current 6 cyl engine. :?
Postby DasLandRoverMan » Mon Aug 22, 2016 12:18 pm
Well a V8 will definitely fit in the chassis...
Users browsing this forum: No registered users and 35 guests
