Postby Wheeledbeast » Mon Apr 04, 2016 5:58 pm
I looks like there was loads of room from the photos ( well there was loads of room, you can see it :!: ), but in the cab that lane felt very narrow and the bends seemed very tight :? .I was actualy a little bit disappointed with the 2.6. it defintly does not have the low down torque of the 2 1/4 .i found it relitivly easy to stall off road. ( although i have not tried a 2 1/4 in an FC, and my Fc is 3/4 ton heavier than my 109). what do other people think :?:
Postby Wheeledbeast » Sun Apr 10, 2016 8:06 am
New alternator fitted, and all is well again. There are no obvious mechanical faults with the old alternator and the brushes seem fine. I will try and get an expert to look at it if it is not too expensive :? .
Tomsmd
Postby Tomsmd » Sun Apr 10, 2016 12:52 pm
Wheeledbeast wrote:I looks like there was loads of room from the photos ( well there was loads of room, you can see it :!: ), but in the cab that lane felt very narrow and the bends seemed very tight :? .I was actualy a little bit disappointed with the 2.6. it defintly does not have the low down torque of the 2 1/4 .i found it relitivly easy to stall off road. ( although i have not tried a 2 1/4 in an FC, and my Fc is 3/4 ton heavier than my 109). what do other people think :?:
I find the combination of 6 Cyl and 1 ton gear box to be absolutely exerllent off road. Smooth application of consistent power and I find the engine quite torquey! The 900s give very good ground clearance too.
Postby Wheeledbeast » Mon Apr 11, 2016 3:49 pm
Is that up higher up the rev range :?: i wonder if it is a difference between a car engine and a land rover one :?:
Postby 1960SeriesII » Wed Apr 13, 2016 8:34 am
I don't have much experience offroad with either the 2.25 or the 2.6, but from what little I could see, with correctly set-up throttle pedal/linkage I have no problems using the 2.6 off the road. I would guess it's on a par with the 2.25, although I can only compare it with my soft-top 88", which really isn't a match for the FC weight-wise. My guess is that the 2.25 wouldn't be doing too well with the FC's weight on its back - after all I suppose that this concern was why Rover started thinking about the 6-cylinder engine in the first place.
After cleaning and greasing the springs I was also surprised by the amount of articulation. Despite all the negative publicity the 2.6 gets, it is quite a nice engine, even if the fuel economy can be terrible if everything is not set up correctly.
I had a bit of a problem with the engine initially, with my ears set up to 4-cylinder music - I wasn't revving the engine the same as I thought the noise would be similar. It isn't - the 2.6 sounds different at the same revs on account of the additional two cylinders, so as long as I was keeping it down to the same levels comparable to the 4-cylinder, it just didn't have the power.
Postby Wheeledbeast » Thu Apr 14, 2016 9:36 am
it seemed fine at high revs, but not when you wanted to go slowly or just increase the power suddenly to get over a bump. ( yes i'm sure the extra weight would over power the 2 1/4, I was just comparing my experience of a 2 1/4 in a regular 109 with the 2.6 in the FC). :)
Postby Wheeledbeast » Fri Apr 22, 2016 3:30 pm
i have found an Australian doppelganger :!: it looks like yellow is the new black :!:
Postby DasLandRoverMan » Fri Apr 22, 2016 7:16 pm
That was in the current CLR magazine, with the owners 1948 80" on the back.
Postby Wheeledbeast » Sat Apr 23, 2016 7:56 pm
Mine has only got 84 inches on the back, you would have to bobtail the SI :D and parkit on its side to avoid the jib :D
Postby DasLandRoverMan » Sun Apr 24, 2016 8:33 am
Or extend the back end and add an extra axle?
Users browsing this forum: No registered users and 22 guests
