Hi
owl
Re: Hi
Postby owl » Sat Nov 24, 2012 1:11 pm
If you look at the pic of the 109 you can see that it is leaf sprung which i like and judging by the six wheel studs I suspect Jap axels though I would try and stick with sailsburys if I could find a front or perhaps modify a rear to take series swivels. I do believe that it is indeed a 6BT which again interest me but at 5.9 lts perhape a bit too much.
I don't have any more pics of the 2B, I seem to have lost many things with moving house a few times. The body on the back was very sturdy and never seemed to flex even off-road the doors would always open and shut no problem. It was low miles and ran spot on plus no rust anywhere. I even ran it on a daily basis for a while movies, shops and out too the pub.
When we went to trials mates would chuck there spares and wheels etc in the back ( I anit got room can I just stick a few bit in yours) and then set of in their v8 powered tow motors and I would be at the back of the convoy struggling to keep up, you know what it's like at the back of a convoy !! but it did pull well if not fast I never needed low box on the road.
I can't imagine what happened to it but would of made a great camper.
and yes it is a KV6.
Re: Hi
Postby DasLandRoverMan » Sat Nov 24, 2012 2:03 pm
There is a chap on the forums who built a IIA FC with a non turbo 6B, he used engine and box from a Roadrunner, and converted the FC transfer box to a remote setup with an overdrive gear ratio (worked out about 0.7 or 0.8:1) which is quite a smart motor. If you look on YouTube for LeFrog you'll find it.
He promised me a drive in it when it was finished (2 and a bit years now) but I'm yet to find the time to go visit. However, that, and speaking to a guy who put a 6BT in a 90 (wagon engine and box close coupled to an LT230) makes me think its a pretty workable setup with some decent front springs.
Axle wise the FC has some ENV's from a IIB, and the 90 was running standard rover items, although he might well have thrown some more money at it by now.
I like the look of your current build, certainly innovative, and I'm guessing built to meet all the ARC rules, but be as light/strong and well balanced as possible.
The chassis looks like a fresh fabrication?
What gearbox are you using, and what engine management?
owl
Re: Hi
Postby owl » Sat Nov 24, 2012 3:20 pm
Le Frog looks good but i think I would go with a 109 and did think of using a lt95 with a short 1st motion shaft and moving the engine back like a six cyl to keep the 2a front.
Yes the chassis is scratch built. the gearbx is a diesel Freelander item which is quite high geared as some of the reduction is done in the IRD. I have had an output shaft made too convert it to LT230 output flanges and there isn't a diff in a freelander box so all sorted plus I can pick it up with one hand so nice and light.
As to engine management it will be on throttle bodies but not sure on ecu as yet.
Users browsing this forum: No registered users and 8 guests
