Recently acquired
Re: Recently acquired
Sounds about right. If you're on the hunt for a pump then I'd suggest a Bosch one from a Tdi (200 or 300, both work equally well) as they're a bolt on fitment in place of the Lucas pump, and make the engines start and run somewhat better with a bit more life about them to boot.
jklandrover
thanks, will try and advise.
- High range
What about this CAV pump?
It seems to be for Santana Land Rover 2,5 Turbo.
http://www.ebay.co.uk/itm/LAND-ROVER-LU ... 3f46a7f2dc
Users browsing this forum: No registered users and 84 guests
